Brief Description: Prep interior for Zolatone, prime
Wend. Worked on papering and taping the inside of the fues.
Thursday Completed taping the inside of the fues. Built a "shield" out of a 2X4 and a sheet than can be used to stop the Zolatone overspary that will be all over when doing the interior. It can be moved around to protect the shop. Zolatone overspray goes very far and stays very sticky for a fair amount of time. It will cover the walls if you don't shield it.
Primed all the interior with gray epoxy primer for Zolatone tomorrow.
