Was time to try the Zolatone. Mixed up 1 quart Lilith Black and Camile white. Looked too white, so added a second quart of black. Mixed up some gray urethane and painted the glove box door and hinge.
Put the Zolatone in the pressure pot and set it at 10 PSI, gun at 65. Sprayed a coat over one of the primed boards from the tailkit box top. Reset the gun to 30 PSI and opened up the fluid nozzle one more turn and sprayed on another coat holding the gun at 36", quite a wide spray pattern.
It came out perfect!!! The wife approved the color and texture. Need a much closer picture to show how it really is. Great for the interior
Started preparing the cabin top interior for paint. It is filled from previous efforts, just needs taping.
