Brief Description: Sand window fiberglass trim, fill
Sanded the fiberglass window trim back to the blue 3M striping tape. Carefully cleaned all the voids, etc and filled with some micro with black die. Should sand to a good finish. Appeares that the edge is clean and sharp. If this fill coat is enough, will pull the striping tape and call it good.
