Wired Light Speed Ignition system inputs and outputs. Wired cooling fan for LS system. Somewhat noisy, resonates the firewall where it is mounted. No insulation, so it will be better with that installed. Laced the LS wires and the wires between the EMS and the firewall. Installed three clamps to hold the EMS and LS wires.
Tied up all wires that penetrate the firewall. These are the grand total of wires that have to pass thru, I think, and hope. This finishes the fues wiring again. One more little thing when theDynon radio arrives. Checked and verified that the wires for it are pulled and in the unterminated cable in the baggage area.
Back to the wing wires tomorrow. Pitot Heat, trim and tip light and strobe.
