Each Skyview display has a USB plug that you need to access to update firmware or data. Located a panel mount pass through and ordered 2. The plug has male/female connectors so you can unplug the wires from the inside. My panel will be complely removeable and will have only the 2 USB and one 15 pin connector to unplug to remove the main front panel, after removing the Skyview displays. Cut holes in the switch cross brace to hold the connectors. Could not find a double connector on the Internet.
Built the reinforcements for the sub panel openings for the radio/glove box stack and for the future Garmin 400 type WAAS. The PAR100EX has a very short tray that required two brackets to pick up the rear mounts as seen in picture 2.
The P.C. board showed up, all 4 copies. They look very good, hope there are not any errors on it. Plugged in the connectors that will solder in place to see what the hub looks like. Need to cut one trace where I connected the power to the two displays together and solder in the Dsubs. Once the main cables are assembled and plugged in, will spend a lot of time checking out the wiring to all the plugs.
