Laid out and cut the two fuse panel doors in the removeable right hand piece of the panel. Started filing. They will use camlocks to close them and hinges on the right. The fuse panel will hinge down off the switch rail.
Got a large order from Stein, wire, wire, connectors, antenna wire, two switchbreakers, Dsub connectors and pins, .... etc.
