Bruces Web Site
Date:  2-28-2013
Number of Hours:  4.00
Brief Description:  Left door, struts, clean-up
Worked over right door and got it working smoothly. Installed struts in both doors, it has wings!
Mounted the Plane Around retention block and drilled and pinned the cam on both sides. Truth is that both doors close without any help from the Plane Around and the left door didn't need much help even with the seal on it yesterday. It sure will be effective as a safety latch.
Will put some more insulation in the side walls before filling them up with wire. Started laying out the location of all the boxes in the Dynon system.
