Brief Description: Glue up left door, door handles
Put wax paper over the door area and a tarp on the inside. With Polly, mixed up a bunch of epoxy and flox. She could spread it about as fast as I mixed it. Put down the thick fiberglass on the two cavaties. Cledoed it up with plenty of squeeze out. Used all the clamps, lead weights and four full cans of housepaint to hold it down.
Built a tent and the hair dryer heater to help keep temperatures up. Outside has been around 28 in the A.M. and 35 pm. Hanger drops to about 49 from 57 overnight with the heat off. I only run the heat while working, four fans in the ceiling keep it circulated. Hanger door is not insulated yet. Rest of hanger is insulated to current house standards and has double pane windows.
Worked on door handles, got handles bolted together.
