Did all nutplates on wings. Not as many, the quick has 16 done when it shows up, there are only 48 to do. Went quickly.
Installed the hinge brackets on the ailerons. Completed and primed the main aileron pushrods and drilled the steel pushrods.
Spent time figuring out how to wire the EFIS systems using a wiring hub such as comes the Vx hubs. Sure looks like a lot of chances to make a mistake! Also looking at intercoms and audio hubs, like the Vx stero mixer. I designed and built a similar audio hub that lets me have two radios with a "select" and "both" switch and a music input. Still is in the -6A working fine. Looks like it is a lot easier now, just $$$$$$$$$$
