Drilled out, deburred, edged and riveted rear seats. Made seat pins and installed.
The good news is that this finishes the major portion of the aluminum part of the fues. The bad news is that the next section is the cabin top.
Will order an Aerosport overhead and center console tomorrow. Also thinking of ordering the finish kit from Vans. Need to do a annual on the -6 and glider and build a cutting table for the wife's sewing room. Also could work on the quick build wing, about 2 weeks or so in it. Also the fiberglass on the tail section.
Vans says 8 weeks on the finish, but the wing quick build said 8 and it took only about twol Will call tomorrow.
