Riveted the rudder pedals with the shop heads facing the pilot. Will give better purchase on the pedals. Assembled the left and right rudder assembly. Installed the plumbing on the brake master cylinders.
Am missing one of the tube inserts for the plastic tubing. Hopefully I have an extra in the stuff I didn't use on my -6A. Used steel braded covered teflon tube in the -6 at a fair expense and about 6 lbs of weight. Will try the stock Vans this time. Must be a lot of them flying.
