Completed all the interior panels. Installed them as they were finished. Looks like the interior of a large airplane. With an unprimed structure, the glare is amazing. Photos don't work well.
I plan to use an Aerosport interior, head liner, overhead console, etc. Will give a finished appearance without a major weight gain.
Changed the support system to make the fues. stable so I can work from the inside. Also lowered it about 6". Climbed in for the first time and made engine noises. Went in and out a few times working on plumbing. First ot thousands of trips into the unfinished fues!
Started installing the brake plumbing that was built earlier. Had to trim back some insulation in the tunnel.
