Deburred, countersunk and dimpled longerons and about 3/4 of the loose parts.
Will go out of sequence before putting it together. Plan to do much of the fuel system and brake lines while it is easy to reach inside with the sides off. Will also install soundproofing in the front, fireproofing the firewall/skin joint. Make templates for the firewall soundproofing/thermal barrier.
Also plan to provide an access hatch to the step attach bolt that can be used to also mount antenna when ADS-B comes on.
