Power outage for 13 hours. Still was able to dimple the skins. 60 gallon air compressor had enough air to dimple edge holes with squeezer.
Had to sort thru all 3/32 cleco to pick out those that would hold in dimples. About 2/3 would not. I have cleco from at least four purchases. Will spray those that work with some paint to ID.
Assembled skins. Still enough air in compressor to rivet about 30 rivets. Will require a bucker to do a lot of the skins.
Started on firewall assembly. Gathered parts. Drilled and riveted recess box.
