Brief Description: Elevator, completed left. Drill out, debur and di
Comp[eted left elevator up to the trim tabs.
Worked on trim tabs. Bent ends, drilled out, deburred and dimpled all. Then countersunk the wrong side of the right spar. Ordererd new spar from Vans, $9.95. The left spar was marked and countersunk on the right side. On to the tailcone.
