Brief Description: Elevator rivet and glue. Start trim tabs
Riveted left elevator front spar. Riveted internal parts at ends and completed rivets. Made foam ribs, cleaned skin, mixed Proseal and glued in foam ribs and trailing edge. Needs to cure.
Built a T.E. bender on one of the tables with some old hinges and a piece of 3/4 ply. Scuffed one trim skin and then bent trailing edge. Worked great. Built 6 trim tab forming blocks.
The Yard Store delivered (in 2 days!) my order for a new dimple die and some other things. Great service. Will be able to continue on right elevator on Monday.
