Removed the engine mount that was temporaily installed,and begain fitting the noae gear leg. It took a good bit of sanding and polishing to let the gear ler rotate smoothly. Drilled the bolt pattern at bottom of gear leg to put on the wheel fork. Went ahead and mounted all three tires on the wheels,while I was at it , then bolted the front fork/wheel/axel assembley to the nose gear leg.Hooked the steering rods to rudder pedals. Looks like progress anyway.
