Installed the two seat panels today. The access holes were precut by Zenith. Just had to cut clearance for the landing gear uprights at outboard edges of panels, and add "L" angles around the under side of the cutout. The rivet lines and nut plate holes can be seen in image 1 on the left panel. The right panel with access cover is in image 2.
