Added the "L" angles to the inside of forward cockpit.The vertical angles went in first after the seven crimps were added to form the curve of side skin. The three horizontal angles were then added over laping the firewall at front, and the vertical angle at rear. Image 3 shows the filler plate and gusset that connect the floor pan to the heel channel.
