Removed all the sharp edges from the main gear attachment weldment.Layed out and drilled the rivet and bolt holes. This 4130 steel is hard on drill bits. Need to get some more # 40s. The gear attachments should very strong,with 16 A5 rivets and 8 AN3 bolts per side.
