Started by cutting hole for the fuel sender in end of tank. The sender float arm was bent to correct shape along with the right wing sender.It was then installed in tank. Self stick cork was applied as per plans and the tank was fitted for filler, vent,and drain holes in leading edge skin. Attached sender wire, ground wire, and fuel line.
