Brief Description: Flap actuator motor and linkage.
Marked the position of the holes in sides of fuselage using the wing fixture and a piece of hinge.Then installed the flap actuator motor. The flap motor is a newer modle than the one shown in the manual. The new motor has the limit switchs built in. After a little head scratching I was able to figure out how to wire the new motor using the old motor diagram. Then set up the linkage temporarily. Looks like the wings and flaps need to be installed before the motor arm is drilled and bolted to the cross shaft.
