Located the attcching plate on the rear frame channel and clecoed. Marked their positions and removed. Then put rear frame channel in place and transfered attach plate location to rear side skins. Made the cut out, installed wing jig to set angle of panel.Installed upper seat & baggage floor support and added gussets that tie the support to the upper front longerons.
