Brief Description: Joined Fore and aft bottom skins.
Joined the front and rear bottom skins at the 6B5-5 gear channel. Spent agood bit of time releveling everything and laying out the center line ofthe fuselage. Put a 3/4 spacer across fuselage at the front edge of rear skins, seen in image 2. Added spar inserts into ends of center wing spar,aligned center spar on bottom skin and clecoed in place.
