Drilled and clecoed the horizontal tail ( H.T.) brackets through the side skin and top longerons. A check of the plumb bob confirmed everything is still square. Started working on rudder cable outlets. Cut the fairleads from sheet of Nylon provided in kit. Drilled and clecoed outlet fairings and fairleads to fuselage.
