Dwights Web Site
Date:  6-26-2007
Number of Hours:  5.00
Manual Reference:  6-B-4
Brief Description:  Rear panel & H.T. section
Added the diagonal L angles to inside of H.T. section. The rear top panel came with the access hole to rudder horns already cut. Panel installed between top of H.T. bulkheads,and top longerons.Then L angles were placed on either side of cut out to add strength.Finally added the upper rudder bearing tab.
H.T. with panel.
H.T. with panel.
L angle stiffeners.
L angle stiffeners.
Upper rudder tab.
Upper rudder tab.
