Cut hole in end of right tank using boring head on Bridgeport. I took the mill out of geag and rotated the head by hand. This worked very well . Hole right on size (2.322) and very few shavings to be cleaned from inside tank. Cork strips applied to tank . Tank set in place between NR3 and NR4. Image #3 shows sender unit in place with ground and sender wires attached.
