Continued wiring panel today. Middle sub-panel wiring is complete (gear switch, lights, and trim/flap indicators). The big question now that the iRiver died is whether or not I cut out the middle of that subpanel and install the key there. It would fit nicely, but I don't want to take a choice spot for that.
Additionally I drilled the holes for the adhesive 'rivets' and readhesed the aluminum angles.
I also installed the dimmer buss and the dimmer knob on the rheostat.
The worst part is that it doesn't look like much has changed!
