DAVE'S WEB SITE
Date:  6-12-2008
Number of Hours:  6.00
Brief Description:  Tightened loose bolts
Jim went around and tightened a bunch of loose bolts, but I had to go back and check them all. He missed all four of the bolts holding the wings to teh fuse as well as the two bolts at the bottom of the struts. Ce La Vie!
I built the gap hinges for the ailerons and flaps today too. What an enormous amount of work for something no on is ever going to see.
The left aileron is on the plane, but the bolts are not tight. I ended up having to cut down the pushrod slightly.
