Spent a lot of time on the turtle deck today/. I painted the inside of it again to enhance the look from inside. I installed nutplates on the tub on the pilot's side. I opened up the opening at the leading edge...I hoped it would make the left side fit better, no such luck. I added a plastic tube around the tailwheel retraction spring to prevent noise from the back and I shrinkwrapped the connection for the transponder antenna. Finally, I rolled the airplane outside and cleaned out the back really well.
