Measured and cut out holes in turltle decking. The manual doesn't cover this step well at all. It simply says cut out the lines drawn on at the factory...well those lines are cheesy sharpie lines. The very front hole is a bit confusing....does it go flush against the forward section of the turtle deck or is it displaced aft 1/4" as drawn? I cut it out 1/4" back. Additionally the last hole measures 3+" X 1 3/4" yet the drawn on lines are only 3/4 X 1 1/2"? I cut out the smaller hole and will have to open it up as I test fit the piece.
