-Finished installing all the fuel lines on the tank
-Wired both fuel pumps. I ended up using the heater wires for pump #2.
-Built coax cable for the transponder antenna. Installed 2 X BNC connectors. They weren't nearly as hard as I anticipated, should be able to crank out the Glasair's without any problem.
-Adjusted drain in the bottom of the tank so it doesn't rub on the bottom of the fuse.
