Finally seated copilot stick grip. It looks like the grip was sitting sl too hi on the tube. What a pain in the ass!
Installed rt side gear cuff.
Cycled gear multiple times. Lt main solenoid is not opening when the gear up more is selected. I can put a jumper across it and get it to open and function, but otherwise, the rt comes up, the left stays down. Additionally I riveted the cams in place on the downlocks.
Tested the trim switches on the sticks through the wiring harness....success! They both worked flawlessly the first time...weird.
Tested the flaps and ran the flap motor using the harness container.
Glued the 90 deg supports on the lower portion of the instrument panel to support the side pieces.
Got a hold of a soldering iron with a knife blade attachment. Mom got it for me at Hobby Lobby.
