Installed elevator guide on lower bulkhead. Had to use an AN4-32 bolt to go through, then lower gear plate rotated and had to jack airplane up to fix it.
Started work on instrument panel. Tried to bend panel, but it ended up warping one section...I may have to replace the whole panel (just the ABS section). The slight warping would drive me nuts over time. I'm going to try to fix it one last time, then this will become the vertical portion of the 'T'.
I tried to buy the stereo/sat radio. Best Buy was useless. They suggested Cruthfield.com.
