Fuselage: Cut out gear leg holes. Minor issue, pivot point center is 1/2" below PA's suggested center. I used the pivot point and then cut the openings undersized until a call can be made to PA. Hole in transom for elevator pushrod cutout as well.
Cockpit: Control sticks installed. AN5 bolt that attaches control stick to pivot causes trouble with all the wires in the stick grips.
