Took skin over to David Clays to use his bending brake to crease trailing edge. Used a dowell rod I think was a little too thick to bend enough. Dimpled and prepped counterweight and test fit fiberglass tip over it. Instructions call to remove more lead for balance purposes. I skipped this for now as I want to find a better way to remove material and want to be closer to knowing how much weight really needs to be removed after building Left elevator with the electric trim motor in it. Again, my theory of better safe than "cut it off 3 times and its still too short..."
