I got my Andair fuel pump kit from England and pump housing parts from Van's. Modified the center floor section, built the pump mount, and put together the pump housing. Decided to go with braided steel fuel lines instead of hard aluminum from the tanks to the selector valve. The gear weldments and support ribs are already installed permanently in the way.
Riveted the firewall recess and rudder pedal support in place. Also finished the last rivets on the bulkheads beneath the cabin canopy frame.
