Russ and Marnies RV-9A
RV-9A
Cowl
I decided to make a spare oil door in case the one I cut doesn't turn out right. It will be of perfect shape and will save lots of work later in case it's needed. I just peeled it off after it cured and put it on the shelf.
Cowl sitting on top of engine before trimming
Layup to use in case I mess up the oil door cut
RV-9A Home
977
