Brief Description: Seat Back Side Channels & Heel Support Blank
I spent an hour in the shop this morning whipping up a few more parts. I'm just going through the really simple stuff now. The things that take a little fabrication will be saved until I have a day off, or can concentrate a little more time on them. I figure I'll bend the heel support the same way I do the gear channel - with a combination of the bending brake and a form block. I'm also experimenting with another method that uses more shallow 30-ish-degree bends to gradually creep up on the 90-degree backward bend needed.
