Debo Cox - Zodiac 601 XL
Date:  1-12-2008
Number of Hours:  3.00
Manual Reference:  6W
Brief Description:  Inboard Leading Edge Skin Fitting (Bottom)
Although I bought the pre-drilled wing skins from Zenith, I did not get the predrilled leading edge skins, so I'm back to drilling them myself. I spent a nice morning taking my time and getting everything all lined up and into it's proper place. I'll continue down the leading edge with the other skins, then flip the wing again to work on the top of these skins. If you don't have one, get yourself a "strap-type hole duplicator." This tool enables you to duplicate the location of holes you already drilled onto a sheet that's going to overlap (like my gas tank skin will.) Mine came in very handy this morning getting my spar rivet line in the right place.
Seen from inboard
Seen from inboard
Now the other direction...
