Debo Cox - Zodiac 601 XL
Date:  1-3-2008
Number of Hours:  5.00
Manual Reference:  N/A
Brief Description:  LRI Probe and Wing Skinning
Spent some time finishing up the wing skinning and fabricating this LRI probe mounting bracket. Scott Laughlin was good enough to send me some pics of his installation, and I used them as a guide. The probe will be mounted at 25% of the wing chord at rib #6 on my left wing - just outboard of the pitot/static tube to keep a lot of the plumbing running through the same conduit. From everything I've read, a good starting point for adjustment of the probe is about 50 degrees - which is what this one is set to now before installation. FYI - 25% of the wing chord at rib #6 is reasonably close to the main spar - about 100mm or so aft of it if I remember correctly. This turned out well. I'm happy with it.
LRI bracket. Angles will be on the outside for adjustment
The completed probe
The completed probe
An interior shot. Arrow points aft.
