Debo Cox - Zodiac 601 XL
Date:  6-11-2007
Manual Reference:  6W
Brief Description:  Block Fabrication/#3 Rib Blanks
Finished dimension-sanding the remaining rib form blocks today. I got them all as perfect as I can get them. They're still not edge-beveled or routed yet, but the dimensions are as per specified on the plans. I also cut out a set of aluminum blanks for rib #3. I'll probably fabricate rib #3 next.
