Debo Cox - Zodiac 601 XL
Date:  10-8-2006
Number of Hours:  4.00
Manual Reference:  6W
Brief Description:  Center spar complete
Finally finished up the center spar this morning. There were a lot of little side projects to finish up before I could do the final assembly, but after a while, there was nothing left to do except bolt it together and rivet the top flange over. The bolts fit nice and tight. They actually had to be hand-pressed into place or driven lightly with a soft-face hammer to get them in place. That's pretty much the fit I was looking for. I torqued the nuts to 65 in-lbs per the FAA manual. Since I had been so meticulous about dimensions, everything fit together beautifully. The top flange was blind-riveted into place with A5 rivets. Good solid structure - it feels very solid and secure, and a lot heavier than any other assembly I've built thus far for this project. Now on to the outboard spars.
Rear of center spar
Rear of center spar
Front of center spar
Side of center spar
Side of center spar
