Debo Cox - Zodiac 601 XL
Date: 12-18-2008
Number of Hours: 3.00
Manual Reference: 6B
Brief Description: Landing Gear Attachments Bolted On
Every once in a while my mind starts thinking airplane things while I'm trying to sleep, and I find myself mentally building an airplane. That was the case last night when I had a bout of aviation-related insomnia. About 1:30AM I started thinking about the gear attachments that were on my list to do, so I finally just got up and worked on them. I must say, these are what I consider to be the trickiest part of the fuselage (so far). Early on, I misdrilled a couple of gussets by not fastening the gear attachment in the right place. I wanted these holes to fit tightly, so I re-made the parts and made sure I had things right before drilling again - which brings me to Cox's Rule of Homebuilding #57: Make sure it's where it's gonna live before you drill it in place! Sounds easy, but it's not always that simple. After fiddling with these for HOURS, I finally got them in the right place. Word of warning - Make sure your bolt heads and nuts have room to operate. Don't drill them too close to the inside radius of a piece of angle, and make sure bolts on opposing flanges of a piece of angle aren't trying to occupy the same space. I think it was Sir Issac Newton who said, and I'm paraphrasing, "Ain't gonna happen." You might notice that on the passenger side front (right) I wallowed out the holes on the bottom two bolts, so I went from AN3 bolts to AN4 bolts. No problem. It's acceptible to use a larger fastener, just not a smaller one. I also put the nuts on the outside of the fuselage for two reasons. Easier inspection, and easier to get to with a torque wrench. Unless you've got some kind of extendo-universal-joint torque wrench, I don't see how you'd get to these after riveting like I did. For the most part, this will be covered by the wing so it won't matter, but I'll be able to inspect and service them easier.
Passenger side gear attachment
Pilot's side (still missing 2 bolts)
The canopy will rest on this edge
Copyright © 2001-2020 Matronics. All Rights Reserved. |
