Debo Cox - Zodiac 601 XL
Date:  6-1-2008
Manual Reference:  6B
Brief Description:  HT Attachments and Rear Fuselage Box Completion
With everything in the rear fuselage pilot-drilled and primary assembled, I've begun drilling holes to their final size and doing final finishing and deburring. I expect this process will take a little time, but after that my plan is to rivet this section together and move on toward the front fuselage section. With good access to the rear section through the top, I don't see any reason to leave it all in clecos - plus I need them to move on! With this section finished, I'll be able to measure the difference in my completed horizontal tail and the attachment brackets to see what I'm up against as far as shimming the old HD-style stabilizer, or building another one.
Everything pilot-drilled
Cable exit
Cable exit
HT brackets
HT brackets
