Brief Description: Beginning Construction on Wings
Well it may not look like much, but with the fabrication of some standard "L" angles and layout of rib stiffeners I began construction on my wings today in earnest. I've been in fabrication mode so long, that it actually felt really good to finally be building an assembly again. If you think about it, I really haven't built an airframe assembly since the end of August last year! All this time I've been fabricating my spars, tanks, and other wing parts. This day has been a long time coming, and it feels great. My plan is to finish up with the stiffeners on both sets of wings for ribs 1-4 as called for, then finish the bellcrank assemblies on rib 7, then drill the holes for the wing attachment bolts. After that, it's attaching ribs to the spar. I've turned a corner here and really feel like I'm getting somewhere now.
