Brief Description: Riveting fwd spar into right side HS
Finished installing and riveting front spar into right HS. Riveted HS-708 center rib into place. I did scratch the forward spar with the bucking bar in a few places. I will clean these up and using a small brush to apply some primer over the scratches before closing up with the rear spar.
