Good day in the shop. Built up the right horizontal stab. I already had the ribs prepped so build up went quick. As expected, it went together much faster than the left. Got it all built up, HS-0005 and HS-0006 rib flanges drilled and then clamped in place. Match drilled and reamed all holes in skins to ribs. Got a little work to finish on HS-702 spar, HS-00003 , HS-810 and HS-814.
