DAVID'S WEB SITE
Date:  9-30-2014
Number of Hours:  3.00
Brief Description:  Fitting Inspection Covers
There some abnormal inspection covers to be fitted for each wing. There are two rectangular plates to help you hook up the aileron cables, and there are one each for the fuel sight guage and the fuel drain. They are unique in how they fit and work, so I started working on getting them mounted. The rectangles are pretty staright forward, so they went quickly. The fuel guage plate needs to be drilled and bushed, but it turned out nicely. Last comes the fuel drain plate. I found a problem with the threads in the fuel tank fitting, so had to go find a NPT tap to clean the threads. Next session I should be able finish that up and the wing prep will be done..
The aileron inspection plates.
