DAVID'S WEB SITE
Date:  9-5-2012
Number of Hours:  4.50
Brief Description:  Right Wing Stitching Finish-Up
This entry represents both a morning and evening session. I finished the stitching on the last two ribs. I then glued down the leading edges as recommended by the Piper manual. With all that done, I started the taping of the ribs. I decided to use the taping method that Legend Cub uses and used one length of tape to go from one trailing edge to around the leading edge and to the other trailing edge. I was pleased with the results, so I'll use that philosophy on the tapes that would actually go around the leading edge.
